enum pointer
TucsonDon
C:
typedef struct
    uint8_t prow[10];
    uint8_t pcolumn[10];
    uint8_t min;
    uint8_t max;
    ModeSec_t name;
    ModeSec_t disp[6];
    PLCDMove lcd_add;
    PputsLCD lcd_dis;
    unsigned set :1;
}TextDisplayAdd_t;
I am using this structure for elements of a menu with ModeSec_t being enumeration type. I want to use a different list for a sub menu w/o having to declare a new structure and current list has 50 elements. What is the most efficient way to point to either list
Separate the general typedef from the instance creation; eg.
C:
typedef struct TextStruct
    uint8_t prow[10];
    uint8_t min;
    uint8_t max;
    ModeSec_t name;
    ModeSec_t disp[6];
    PLCDMove lcd_add;
    PputsLCD lcd_dis;
    unsigned set :1;
TextStruct TextDisplayAdd_t;
TextStruct TextMenu_t
rjenkinsgb thanks for the info. The issue that I have is ModeSec_t is a typedef'ed enum list. I want to change this to point to that list or another list w/o declaring another variable (i.e. the same variable for either list)
A union with pointers to both types?
You could use a void pointer, but you would need to cast it to the correct type every time it was used anywhere.
rjenkinsgb I am unsure how I need to do that, I know how to do a union, just not the way you suggest.
Something like:
union uptr {
TextDisplayAdd_t * txtptr;
ModeSec_t * modptr;
uptr.txtptr and uptr.modptr
Same memory location, but the context tells the compiler which type of data is being addressed.
Something like:
union uptr {
ModeSec_t * modptr;
TextDisplayAdd_t is a structure type with ModeSec_t name and ModeSec_t disp[6] elements. ModeSec_t is an enumeration type. I want to make the array to point to ModeSec_t or another enumeration type.
Not quite sure I follow you here, but you can't have a pointer to an enum type. You can have a pointer to a variable of type ModeSec_t, but not ModeSec_t itself.
An enum type is just another definition for an int, so it has no storage. In your structure above, 'name' and 'disp[6]' are just fancy names for integers.
tumbleweed thanks for the info
