Hi All,
A little problem in that I was trying to help someone else but realised I did not understand things properly my self.
I have seen the recent EQU v DEF thread but it does not help clarify the point.
Typically in books you see the authors use code examples like this
STATUS EQU 03
Z EQU 2
COUNTER EQU 0C : 16C71 chip
When using the EQU with the COUNTER label, the expression value creates a entry in ram for that label.
When using the label Z it save the value of 2.
Address 2 is the PCL so must assume it does not replace that - so where is the value held once programmed ?
Similarly what determines if its a user register is to be created or a value to be retained ? - is it simply the fact you would write to the user register ?
thanks
STATUS EQU 03
Z EQU 2
thanks
