Porting an existing Arduino project over to the ESP32 WRoom32 board.
If I run just this example EEPROM code on the ESP32 it returns the data correctly.
However when I tried running my original EEPROM code in the project code it does not work returning values of 0.
So I added the test code below, as the first lines of code in the SetUp section of my project code, but it also would not run correctly , just returning 0 and 0
The project is using the following libraries so wonder if there is some form of contention ?
Whats not quiet clear from the info on the ESP32s EEPROM is does the EEPROM commit() have to be run after each EEPROM Write or just after a block of Writes ?
There seems a lot of quiet complex info on the web about varoius way of using the ESP32s Flash memeory as EEPROM; is this simple method below stable enough for saving a few bytes each hour ?
Project Libraries -
EEprom test code, ok when run independatly, but fails when run in the project code -
Project Libraries -
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <EEPROM.h
#include "Sodaq_DS3231.h"
#include "Adafruit-GFX-Library-master\Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#include "SPI.h"
#include "XPT2046_Touchscreen.h"
// include library to read and write from flash memory
#include <EEPROM.h>
// define the number of bytes you want to access
#define EEPROM_SIZE 60
byte DataE = 35;
byte DataD = 44;
void setup() {
Serial.begin(115200);
// initialize EEPROM with predefined size
EEPROM.begin(EEPROM_SIZE);
void loop() {
EEPROM.write(0, DataE);
EEPROM.commit();
EEPROM.write(1, DataD);
EEPROM.commit()
delay (1000);
byte TEST = EEPROM.read(0);
byte TEST1 = EEPROM.read(1);
Serial.println (TEST,DEC);
Serial.println (TEST1,DEC);
delay (100000);
