Yes.. It is the correct word... RADIX can be hexadecimal, octal, decimal or binary..Edit, decimal is the wrong word but I'm not sure what would be correct.
Doesn't the "Data Memory" contain 4 sections - .data, .bss, stack and heap - in a way that the stack and heap sections are separated from the .data and .bss sections?
Back to the main question.... Which architecture???Hi Ian.
Thank you
Could you recommend on some good link for memory architecture?
I'm not quite sure i understand what you said and it probably since i lack of knowledge.
It makes sense to me but maybe you should change the hex addresses to match the decimal. I.E 128k should go to 0x1FFFF.
are the 32 registers what are called SFR registers?
