External interrupt program won't work
Cantafford
Hello. I'm trying to learn to use external interrupts with PIC microcontrollers. I wrote a piece of code which is supposed to keep a led off untill an external interrupt from a push button occurs. I have connected the pushbutton to RB0 pin as I will be using the INT0 to occur on falling edge. The LED is connected on RC0 pin of the microcontroller as you can see in the image I've uploaded:
This is the main code:
 * File:   main.c
 * Author: Paul
 * Created on February 27, 2016, 5:27 PM
#include <stdio.h>
#include <stdlib.h>
#include "header.h"
void interrupt CheckSwitch()
    if(INTCONbits.INT0F == 1) // if interrupt has occured
        for(int counter=0; counter<5; counter++) // flash led 5 times
            LATCbits.LATC0 = 1;
            for(int delay=0; delay<20; delay++) __delay_ms(5);
            LATCbits.LATC0 = 0;
        INTCONbits.INT0F == 1; // then clear interrupt flag
void main()
    OSCCON=0x76; // 8 Mhz oscillator
    TRISCbits.RC0 = 0; // led is here
    TRISBbits.RB0 = 1; // button is here
    INTCONbits.PEIE = 1;
    INTCONbits.GIE = 1;
    INTCONbits.INT0IE = 1;    //enable Interrupt 0 (RB0 as interrupt)
    INTCON2bits.INTEDG0 = 0; //cause interrupt at falling edge
    INTCONbits.INT0F = 0;    //clear interrupt flag
    while(1)
      LATCbits.LATC0 = 0; // keep led off
And this is the header file.
 * File:   header.h
 * Author: Paul
// PIC18F2550 Configuration Bit Settings
// 'C' source line config statements
#include <xc.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1L
#pragma config PLLDIV = 1       // PLL Prescaler Selection bits (No prescale (4 MHz oscillator input drives PLL directly))
#pragma config CPUDIV = OSC1_PLL2// System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
#pragma config USBDIV = 1       // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes directly from the primary oscillator block with no postscale)
// CONFIG1H
#pragma config FOSC = INTOSCIO_EC// Oscillator Selection bits (Internal oscillator, port function on RA6, EC used by USB (INTIO))
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF       // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = OFF        // Brown-out Reset Enable bits (Brown-out Reset disabled in hardware and software)
#pragma config BORV = 3         // Brown-out Reset Voltage bits (Minimum setting)
#pragma config VREGEN = OFF     // USB Voltage Regulator Enable bit (USB voltage regulator disabled)
// CONFIG2H
#pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = ON      // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = OFF     // PORTB A/D Enable bit (PORTB<4:0> pins are configured as digital I/O on Reset)
#pragma config LPT1OSC = OFF    // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON       // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = ON         // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
#pragma config CP1 = OFF        // Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
#pragma config CP2 = OFF        // Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
#pragma config CP3 = OFF        // Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
#pragma config WRT1 = OFF       // Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
#pragma config WRT2 = OFF       // Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
#pragma config WRT3 = OFF       // Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
#define _XTAL_FREQ 8000000
The program is supposed to keep the led off and when the button is pressed an interrupt service routine should occur that will flash the led. But when I press the button nothing happens(the led stays off). What am I doing wrong?
You're only flashing the LED ON for 5mS, and a total time of 50mS - that's probably far too short to notice? - give it a LOT longer (say 500mS per flash).
In the interrupt routine:
should be:
INTCONbits.INT0F =0; ?
Yes correct. Didn't see that mistake. I have modified that and also made the program to just keep the led off and turn it on upon hardware interrupt but still it doesn't work :(. The led stays off all the time. Here is the code:
 * File:   main.c
 * Author: Paul
#include <stdio.h>
#include <stdlib.h>
#include "header.h"
            LATCbits.LATC0 = 1; // turn led on
            INTCONbits.INT0F == 0; // then clear interrupt flag
void main()
    INTCONbits.GIE = 1;
    while(1)
You do realise that your MCLR is on!! You need to pull the pin high!!
Just a note on copy and paste!!! if(INTCONbits.INT0F == 1) pasted to INTCONbits.INT0F == 0;
Just note " == " is equality NOT equal!! Pitfalls that catch you every time...
Just tested your first code... Works great....
