external oscillators
amr_karimm
hi ,
i ask befor to feeding asmart card with oscllation clock by only on pin (xtal1) for at90s8515 i asked for have the clock from the pic which i use it to read the card
i want to know if i connect the pin of card with (xtal1) or (xtal2) of hte pic
thanks
amr_karimm said:
hi ,
thanks
The PIC pins are clearly labelled on the data sheet, for example pin 15 of a 16F628 is labelled RA6/OSC2/CLKOUT, whereas pin 14 is labelled RA7/OSC1/CLKIN - so to feed the PIC oscillator to another device you would use CLKOUT. Bear in mind though that any heavy load will stop the oscillator.
