I'm looking for a transistor with a ridiculously low Vce(sat) if possible. It needs to supply 250ma to a load, and will be driven by an output pin of a PIC (so 15-20ma drive current available I guess).
A logic level power Mosfet will have an extremely low saturation voltage when the current is only 250mA.
For example, An IRF3711 has a typical saturation voltage of only 1.5mV when its gate voltage is only 4.5V and will be lower when the pic drives its gate up to 5.0V.
I can't use a MOSFET here due to 3V operating voltage on the PIC, and needing to generate 1V across a load with an H-bridge. Which, on the top side of the h-bridge, only gives me 2V for a gate voltage I'm not experienced with transistors (I always use fet's for switches) so I didn't know how low Vce(sat) can get on nice parts, but since turn-on voltage is .7 or 1.4V I was thinking they might be an alternative.
Zetex has some low saturation bipolars in the range of 250mA.. also you said you can't use a mosfet but you can buy low logic level fets with 1.8V VGS(th) maximum.
It really sounds like almost any small transistor will do - but you don't actually mention what it's for, or why you think you need a "ridiculously low Vce(sat)".
