Dragon Tamer
I have been making a fan speed controller using a 555 and an op-amp on the control pin said 555. I was reading an article about fan speed control and the advantages of each. It says that for PWM it is best to use a frequency between 20Hz and 160Hz. The problem with that is it will put the PWM frequency right in the audible range and would likely be amplified by the amplifier circuit. Right now I have the PWM frequency set to 100kHz and a duty cycle between 15% and 85%. The article said that a lower frequency will increase the life of the fan itself, but I don't want to hear the noise the fan makes through the power bus.
How long should the fan last with a frequency of 100kHz? (if I asked the company they would have just asked me to buy one of their fan control chips)
