Hi guys, am new in this forum, not much into electronics ,and looking for some help from experienced guys like you, thats why I got here.
Well am searching for an actuator solenoid to use it in my car, here are my requirements regarding the actuator solenoid:
1- Compact size, not larger than 100mm.
2- 12V to be used in car.
3- The stroke got to be at least 25mm.
4- Strong enough to push at least 6Kg.
5- very fast open time, less than 1 sec if possible.
Am going to use the actuator solenoid to be able to push my car throttle wide open when I left off my leg from the gas pedal, this actuator solenoid will be controlled from aftermarket ECU for the Anti Lag, to be able to activate the anti lag correctly I have to open the throttle at least 12%-15%, and I want it to be strong one becuase as you know the throttle got spring on, so it can close it back when the driver pull-off his leg from the gas pedal, and its a strong spring needs some force to be opened, and want it to be fast, because anti lag works in milliseconds and its effect will be hard on the engine.
So where I can find such actuator solenoid ?!?!
here a link about anti lag so you can get the better picture, thanks in advance guys and appreciate your help.
Turbo Anti-lag systems - A technical description
Dukhqan.
Dukhqan.
