Good day everyone!
I have a hair straightener that I’d like to repair. Recently I was traveling and I was powering the device with a voltage converter that delivered too much voltage. The device is rated for 100V, and the converter delivered 120V.
The straightener worked for a while, and eventually I heard a pop, and the device failed. If I plug it in and try to turn it on, the LED doesn’t light up and the heating elements don’t warm.
Looking at the underside of the PCB, I can see that there’s quite a bit of carbon residue around some of the solder pads. The scorching seems to come from the wires that connect to the heating elements. There’s no scorching on the top of the PCB where the components are located.
None of the wires on the device look like the plastic melted. Also, some of the wires are a bit more exposed than I’d expect. I’m not seeing that any of the exposed wires are touching each other. Though, some of the exposed wire do touch the PCB around the edges.
All of the components look just fine… unless there are components inside the second half of the device. I didn’t disassemble that half.
I’m fairly new to hobby electronics and my electrical theory is very limited, but I want to learn! I’d be so grateful for any guidance on how to diagnose the exact problem and how to subsequently repair it.
Summary
Device: Hair straightener
Brand: GAMA Italy
Age: 7+ years
Cause of fault: powered with 120V when rated for 100V
Symptom: Popping sound, device does not warm and LED doesn’t light. Bottom of PCB scorched
Images
Overview of device
Closeup of top of PCB that receives voltage input
Reverse of PCB
Some images showing the components on the top of the PCB
Summary
Brand: GAMA Italy
Age: 7+ years
Images
Overview of device
![7JGxOgX.jpg](https://img.imgur.com/7JGxOgX.jpg)
![rNjGpYm.jpg](https://img.imgur.com/rNjGpYm.jpg)
Reverse of PCB
![IH0iQZE.jpg](https://img.imgur.com/IH0iQZE.jpg)
![4tf9iuJ.jpg](https://img.imgur.com/4tf9iuJ.jpg)
![cVMbP2p.jpg](https://img.imgur.com/cVMbP2p.jpg)
![HDKUScu.jpg](https://img.imgur.com/HDKUScu.jpg)
