I found this diagram
on this site and whis to know if you don't need a reverse biased diode like you need when using a BJT to eliminate spikes at startup and shutdown operation.
PS author mention that FETs normaly need voltages higher than 10V at the gait to conduct through drain - source. Do FETs that could be controlled directly from PIC output exsist?
![167-picmin5.gif](http://static.electro-tech-online.com/imgcache/167-picmin5.gif)
