Relay221
hi I need help with calculating the cutoff frequency Fg. There are several formulas, but I don't know which one to use because every time I get out a different value in (Hz).
Below is the schematic of this filter (active band pass filter) + its characteristics.
I care about the correct solution If I misunderstand something or there is an error in the diagram in the characteer please correct me
characteristics (calculated using excel):
I am not 100% sure about what I drew , but it seems to me that there is a fmeasure otherwise fg but it is calculated with the value of delta f0 or delta f10 from the characterization . I marked fmeasure for -3dB delta f0 and -20 dB delta f10 .
But I still need fcalc (calculated from the formula to later calculate the percentage of measurement error) And from what I tried I got the formula in school . fcalc=1/(2π√LC) but it seems that the formula is not correct or I don't know how to calculate it . Using chat gpt I found out that there is a formula Fg= fl+fh/2 Where fg is the cutoff frequency,fL is the lower cutoff frequency, and fH is the upper cutoff frequency . I don't know if the formula is correct and I did everything right but please correct me if necessary![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
