Figuring ADC values from a phototransistor
Mosaic
I am looking for comments/advice on this approach.
In order to devise an autodimmer PIC routine fed by a Photo transistor/diode of this type
Which goes from dark (20) lux at 70uA (Coll.-Emitter current max) to 100 lux at 200uA , ambient light.
The device is NPN so its a current sink.
That 70ua works out to 5V across a 71k resistor, the 200uA is like 5V across a 33k.
I need some guidance on establishing a decent voltage difference at the ADC pin to measure. I am not sure how much the adc pin's loading will affect this. A pull up resistor is required to provide current sourcing.
Since I am looking for just light or dark switching, perhaps a small capacitor charge/ discharge cct fed by the phototransistor can be timed by a regular input pin. By forcing the cap low (with output low from the pin) and then input sampling until the cap goes logic hi might give a time that decides bright or dark.
If you just want to detect illumination, simply connect the photo transistor directly to an input.
By adjusting the value of the load resistor you will be able to adjust the point at which the circuit changes state.
A FPT100 is a single photo transistor and it works even better than the darlington shown in the diagram.
