Hello Everyone,
I am making a custom circuit board with many different parts(dc dc converters, chargers, battery management, battery protection, isolation, etc)....
The product is to run on 18650 Li-ion battery cells, and if you are wondering why I don't use the ones with built in protections, it is because the shutoff point is different, and we have batteries already without the protection, that will be made into 4-cell parallel packs...
Anyway, to the point that I am getting to....
I found the IP5306 Charger/Boost converter with a built-in fuel gauge, and that is EXACTLY what I am needing...
Except.... there are a few problems.
- I have to use google translate to read the datasheet(Means it's not a commonly used/stocked part)
- The ship time from anywhere I can find is between 60 and 90 days
- And it is not stocked by ANYONE in the U.S.
So, I went to trying to find an equivalent off digikey.com, and mouser.com, and every other place I could think of(Analog Devices, ON Semiconductor, Texas Instruments, ...)
And the only things I can find are 64 pin BGAs and 56 pin QFNs that cost $32 apiece, or else they have to communicate with I2C, which I think means they have to be programmed...
And plus, they have hundreds of features that I do not even want, much less need....
So my question is
Does anyone know of any place I can look for something like this?
Am I going about my searching the total wrong way?
Does anyone know of any components that might work for any one of the functions I am needing from the IP5306?
And, I am having the same problem with the protection IC that I found, which is also produced by INJOINC, the IP3005....
Here are the links for the two ICs...
https://lcsc.com/product-detail/PMIC-Battery-Management_IP5306_C181692.html
lcsc.com
Thanks everyone in advance!!!!
So my question is
IP3005A INJOINIC | C181685 - LCSC Electronics
IP3005A INJOINIC $0.1287 - ESOP-8 Battery Management ICs ROHS datasheet, price, inventory C181685
