Oznog
Active Member
I've seen a number of routines that do bit banging on a serial port. But I don't get how they handle framing problems. There's an assumption that the code can start looking for the start bit at the start of the loop. If the code starts the loop in the middle of a byte though this won't work. First 0 in the bus it'll assume is a START bit. There's a good chance a 1 won't happen in the window it will look for the STOP bit in so it may realize there's a framing error.
How does the bit banger figure out what the start of the byte's framing is?
