first byte get...next byte NOT get
hhhsssmmm
Howdee people.
I have just completed an I2C interface to get two PICs talking ... MASTER and SLAVE setup.
This is working......but after successfully reading the first byte from the SLAVE and displaying on MASTER LCD ....if the MASTER again requests to read another byte from the SLAVE....then the two PICs seem to lock up...or so it seems anyway....and i do not get any more bytes received from the SLAVE.
So in short my I2C link only works for the first byte reception...after which it locks up.
Please can someone help me here to fix this problem.
my setup is...
PIC18F4423 (MASTER) and PIC18F2420 (SLAVE)
Master @ 20Mhz ceramic clock
Slave @ 8MHz internal clock
compiler used C18
Below are my test codes of MASTER and SLAVE.
thank you
hhhsssmmm
MASTER CODE
void main(void)
    unsigned char ABC, DEF, HIJ; //byte holding variables
    ABC = read_from_slave_PIC(0xD0); //reading from SLAVE PIC (address)
    DEF = read_from_slave_PIC(0xD0); //reading from SLAVE PIC (address)
    HIJ = read_from_slave_PIC(0xD0); //reading from SLAVE PIC (address)
    //PRINT FIRST BYTE
    SendLCD(0x80,0); //activate LCD line 1 ... col 1
    //print the data byte on LCD
    SendLCD(ABC,1);
    Delay10KTCYx(125); //250ms delay
    //PRINT SECOND BYTE
    SendLCD(0x81,0); //activate LCD line 1 ... col 2
    SendLCD(DEF,1);
    //PRINT THIRD BYTE
    SendLCD(0x82,0); //activate LCD line 1 ... col 3
    SendLCD(HIJ,1);
    while(1); //loop forever
} //end of main()
unsigned char read_from_slave_PIC(unsigned char address)
    unsigned char data_byte = 0; //variable to hold the data byte from the SLAVE
    OpenI2C(); //INITIALLIZE & Configure I2C PORT
    StartI2C(); //Generates a Start I2C condition
    IdleI2C(); //Loops until I2C BUS is Idle
    if(DataRdyI2C() == 0) //proceed if buffer is empty
        //Send WIRTE command to SLAVE ... LSB is '0' as the WRITE bit
        if(WriteI2C(address) == 0) //ACK not received from SLAVE
            I2C_Error(); //Stop and rest I2C if link between PICs fails
            while(1); //STOP program
    StopI2C(); //Generates a Stop I2C condition
        //Send READ command to SLAVE ... LSB is '1' as the READ bit
        if(WriteI2C(address + 1) == 0) //ACK not received from SLAVE
    data_byte = ReadI2C(); //read the received data from the SLAVE
    NotAckI2C(); //Generates a Not Ack condition after reading data
    return data_byte; //return data byte from SLAVE
}//end of read_from_slave_PIC()
void OpenI2C(void)
    //Reseting MSSP registers
    SSPCON1 = 0x00; // power on state
      SSPCON2 = 0x00; // power on state
    //Selecting & Configuring I2C Master mode
    SSPCON1bits.SSPM3 = 1;
    SSPCON1bits.SSPM2 = 0;
    SSPCON1bits.SSPM1 = 0;
    SSPCON1bits.SSPM0 = 0;
    SSPSTATbits.SMP = 1; //Slew rate set to NORMAL speed @ 100kHz
    SSPADD = 0x63; //setting baud rate 100kHz (NORMAL)...PIC running @ 20MHz
    SSPSTATbits.CKE = 0; //Disable SMBus
    PIR1bits.SSPIF = 0; //reset MSSP interrupt flag bit
    SSPCON1bits.SSPEN = 1; //Enable I2C Master port
}//end of OpenI2C()
void NotAckI2C(void)
    SSPCON2bits.ACKDT = 1; // set acknowledge bit for NOT ACK
    SSPCON2bits.ACKEN = 1; // initiate bus acknowledge sequence
}//end of NotAckI2C()
void IdleI2C(void)
    //Test and wait until I2C module is idle
    while ( (SSPCON2 & 0x1F) | (SSPSTATbits.R_W) )
        continue; //keep looping until idle
}//end of IdleI2C()
unsigned char DataRdyI2C(void)
    if(SSPSTATbits.BF == 1)  // test if buffer full bit is set
        return 1;          // data in SSPBUF register
    else
        return 0;          // no data in SSPBUF register
}//end of DataRdyI2C()
unsigned char ReadI2C(void)
    SSPCON2bits.RCEN = 1;     // enable master for 1 byte reception
    while (SSPSTATbits.BF == 0); // wait until byte received
    while(PIR1bits.SSPIF == 0); //wait for interrupt
    return SSPBUF;    // return with read byte
}//end of ReadI2C()
unsigned char WriteI2C(unsigned char data_out)
    SSPCON2bits.ACKSTAT = 1; //reset ACK bit flag
    SSPBUF = data_out;       // write single byte to SSPBUF
    if(SSPCON1bits.WCOL == 1)  // test if write collision occurred
        SSPCON1bits.WCOL = 0;     //Reset collision bit
        while(SSPSTATbits.BF == 1);   // wait until write cycle is complete
    if(SSPCON2bits.ACKSTAT == 0) //Was there an ACK sent from DS1307?
        return 1; //DS1307 sent ACK
    else
        return 0; //No ACK was sent
}//end of WriteI2C()
void StartI2C(void)
    SSPCON2bits.SEN = 1; //Initiate Start condition
}//end of StartI2C()
void StopI2C(void)
    SSPCON2bits.PEN = 1; //Generate Stop condition
}//end of StopI2C()
void I2C_Error(void)
}//end of I2C_Error()
SLAVE CODE
void main(void)
    //I2C SLAVE mode, 7 bit address, with Start & Stop bits interrupts enabled
    SSPCON1bits.SSPM2 = 1;
    SSPCON1bits.SSPM1 = 1;
    SSPADD = 0xD0; //SLAVE address is (7bit). Lsb is R/W flag bit
    SSPCON1bits.CKP = 1; //Clock Released
    SSPCON1bits.SSPOV = 0; //Clear Buffer Overflow
    INTCONbits.INT0IF = 0;  //Reset the INT0 External Interrupt Flag bit
    INTCON = 0b10010000;  //Enables all high priority interrupts
                            //Disables all low priority peripheral interrupts
                          //Disable the TMR0 overflow interrupt
                          //Enables the INT0 external interrupt
                          //Disables the RB port change interrupt
    d0 = SSPBUF; //clears BF
    d0 = 'R';  //assign data byte to be sent to MASTER
} //end of main()
void HighInterrupt (void)
    if(PIR1bits.SSPIF == 1) //if MSSP interrupt
        if(SSPSTATbits.S == 1) // Slave receives address/data after start
            if(SSPSTATbits.R_W == 1)    // Read request from master
               SSPBUF = d0;             //load data byte for transmit
               SSPCON1bits.CKP = 1;        // Release SCL line to start transmit
               while(SSPSTATbits.BF == 1);    //stay here until BF is cleared
            //recieve data from master
            if (SSPSTATbits.D_A == 1)        // Data [not address]
                d3 = SSPBUF;                 // get data
        if(SSPSTATbits.BF == 1) //buffer is full so empty it
            d4 = SSPBUF; // read buffer to clear flag
}//end of HIGH ISR
