First Use of PIC Simulator - Basic LCD test Example
eTech
Hi
Trying out PIC Simulator with Example 1: Basic LCD test
I have the program loaded and runnning but have no ouptput on LCD Module.
Screenshot attached.
Also tried the 7segment.bas example, no output on 7-Segment Display.
Can anyone help?
eT
Hi
Can anyone help?
eT
Nervermind.....its working...
hi eT,
You should , when using long delays in SIMULATION add this line, at the top of your Basic code.
Define SIMULATION_WAITMS_VALUE = 1
Otherwise a delay of WaitMs 1000 will be a very long delay, due to the slow speed of simulation.
Also add a simple LCD test line after LCDINT, something like LCDOUT "Ready" will show the LCD is working OK.
hi eT,
Hi Eric,
Regarding my initial post. As you probably guessed, I found I just wasn't waiting long enough.
Thanks for the info..
I'm really liking the simulator...awesome!!
I'm very comfortable with Basic, but does it support C language?
eT
Kind of!! If you successfully build a C project in MPLAB you can run the hex file in the sim.... It will be very slow as you can't speed up the delays ( Unless you comment them out for simulation )
But you will need to be up there with assembly for debugging.
