yngndrw
Well I want to make a simple bench PSU which will give out: +-12V @ 1A and +-5V @ 1A.
Looking through my CPC catalogue, I've made the following design [Attached]. (Although the -12V is now limited to 0.5A, due to the limitations of CPC.
Parts list and prices:
Questions:
1) Suggestions / Improvements ?
2) What size heatsink would I need for ALL the regulators AND the bridge rectifier ? Note: The regulators and bridge rectifier will be mounted to the side of a small die-cast aluminium case, with the heatsink bolted to the outside.
Thanks,
-Andrew.
[b]Parts list (CPC Part Numbers) - Prices in GBP, excluding VAT
[ Ref - CPC Part # - Description - Price (Total) ][/b]
T1 - FF01553 - 60VA Toroidal 2x15V - £10.85
BR1 - SC05773 - KBPC601 (50V, 6A Bridge Rectifier) - £1.97
RG1 - SCL78S12CV - L78S12CV (+12V, 2A Regulator) - £0.99
RG2 - SCL7912CV - L7912CV (-12V, 1.5A Regulator) - £0.72
RG3 - SCMC7805CT - MC7805CT (+5V, 1A Regulator) - £0.26
RG4 - SC05482 - MC7905CT (-5V, 1A Regulator) - £0.39
C1 & C2 - CA04567 - Aluminium Electrolytic 2200uF 50V - £3.10
C3 & C7 - CA04503 - Aluminium Electrolytic 3.3uF 50V - £0.20
C4 & C8 - CA04506 - Aluminium Electrolytic 22uF 50V - £0.26
C5 & C9 - CA04501 - Aluminium Electrolytic 1uF 50V - £0.20
C6 & C10 - CA04558 - Aluminium Electrolytic 10uF 50V - £0.14
D1 - LP00348 - 12V 5mm Green LED - £1.37
SW1
F1 - FF00394 - 3.15A TD 1 1/4" Fuse (10 Pack) - £1.18
F2 & F4 & F5 - FF01404 - 1A QB 20mm Fuse (10 Pack) - £0.58
F3 - FF01393 - 500mA QB 20mm Fuse (10 Pack) - £1.13
[b]*Others:[/b]
Fuse Holders (x4) - FF01330 - 20mm Fuse Holders (x4) - £1.04
Mains Inlet - CN09935 - Power Socket, Fuse Holder, Switch Module - £3.25
Regulator Insulators - SCW353PK - TO-220 Insulators (10 Pack) - £1.85
Case
Heatsink
[b]*Total Price (+Case and Heatsink):[/b]
Without VAT = £29.48
With VAT = £34.64
Questions:
Thanks,
-Andrew.
