bmcculla said:There's a comapny called minco that makes flexible PCB that you can solder components to. Its quite flexible- like a thick plastic bag.
Brent
bmcculla said:The flexible circuit shouldn't be damaged by bending unless the bends are very sharp. Its a little stiffer than a plastic bag.
Single layer PCBs have only a single layer of copper traces. Multi layer PCBs have several copper layers stacked up and can be connected with vias between the layers. The more layers on a PCB the more complicated the circuit can be. 2 or 4 layers is fairly standard.
marvelous said:Now....if i increase the number of layers of the FPCB, can i make my circuit smaller and smaller?
