Flyback diode
Makaram
Running 36v dc motor that draws approximately 5-10A continuous.what fly back diode should I use to protect my h bridge fets? Specs or a calculation or simply a suggestion would be most appreciated
Thanks,
matt
If you are switching over say about 400Hz you should use a high speed diode like a Schottky rated for the full current plus some headroom.
Under that frequency you can get away with an ordinary rectifier diode rated for the full current plus a little more for headroom.
I was under the impression that fly back current would only be a fraction of the forward current?
Hi again,
Well now's your chance to stop being under that impression :)
Seriously though, the current through the inductor theoretically does not decrease in the first few instants of the 'flyback' operation, so it would be good to have a diode that can handle the full current.
A snubber is often used when there is a danger of a short high voltage spike from occuring in spite of having a diode and blowing out some other component. You many not need one.
