JimB said:What you need is a high-pass filter...
Any wideband noise on the mains will interfere with your signal...
You need to consider the components connecting the circuit to the mains, they need to be rated for mains voltage and provide reliable isolation. An HF transformer would be a very good idea.
Must you use the mains? Is it not possible to run a separate cable?
