I have found a module that is a tranciever, that takes SERIAL INPUT and outputs SERIAL data on the outputs. It includes all decoding ONBOARD which converts the data using manchester coding, so i just supply it with SERIAL DATA... which is EXACTLY what i need in one package, BUT
the price in the UK seems a bit pricey, £18 per module, i need three @ the same frequency (1 x master and 2 x slaves)...flow of data is controlled by the MASTER hence i shouldnt get conflict as im using same frequency..
The modules i have looked around for, alot do not state SERIAL DATA interface, if i was to purchase an encoder/decoder chip, what could i then interface too? any FM module? or does it still need to be able to accept "UART/SERIAL data"?
The data sheet of the 1 i want to use is attached, as i say £18 is the cheapest, if i can get sub-modules that come up to £10 then i will probably look into that, if not much less that £18 i might aswell get this all in 1 package
