Hello All,
I have wondered on this Chinese module same like other multinational electronics giants as well?![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm here today going for a short review on this particular entertainment circuit module which is getting much popularity nowadays -the brilliant yet cheap SD/MMC USB FM module from China with LED display!
This one I have taken from a non-working stereo amplifier package, uses two bridged LA4440 IC's capable of providing 20+20W in to 4ohms. These local assembled systems are very popular nowadays here.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
These modules are nowadays widely used in the portable battery powered low voltage entertainment speakers as well as the high power low cost stereo amplifier packages. I can see a lot of local manufactures in India imports these modules and assembles their own systems. Most of those portable ones uses a rechargeable 3.7V lithium battery and says Nokia BL-5C mobile phone battery compatible. I assume they might have used double BEL 1895 low voltage mono audio amplifier module, but I'm not sure on this.
I had a few experiments with this on this Sunday to evaluate it's performance. I would say I'm truly amazed and happy enough to give ++ to those brilliant Chinese engineers behind this![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Module specs:-
*) FM/AUX/USB mode selection
*) Auto search and save preset FM channels
*) Brilliant simple LED display for preset channel no./song number/frequency/volume/seconds elapsed
*) Around 500mV L/R audio output with nice frequency response
*) Sensitive enough to clearly receive FM channels with a short length of wire.
*) Good stability on FM.
*) 45db channel separation
*) In built 4 mode preset equalizer
*) Audio mute
*) Last played/volume level memory
*) Low supply voltage range between 3-5V, 5V regulated recommended.
*) All functions remote controlled with volume levels from 0-50
*) Good build quality and uses single electrolytic cap. Assume very good reliability as well.
*) Scope for wide range of applications
I couldn't see a step by step channel search, but it doesn't bothers me because the auto search is sensitive enough to lock on all the available channels. It may bother you if you want to tune into a particular distant channel which require some sensitive antenna adjustments.
I have had a few experiments with this using my low voltage audio amp TA7368 connected to one of the output channels with 4xAA batteries. The module+ amp combination drains good current I assume, also the module is equipped with 4 LED seven segments. My 2000mah eneloops were in almost finishing stage while on experiment, still able to play continuously for around 2 hours. A fully charged batteries might give an operation time of more than 5hours I assume.
There I can see a Line-input option as well, which I assume capable of providing digital audio processing through the module.
The tiny remote control receiver on the module is powered using 3.3V available from board.
Below are some photos provided with this short review. I have been so happy with the performance of this brilliant Chinese module. These modules alone are available as replacement parts in market in a cheap rate.
This is capable of presenting you a nice day with some great experiments, I would say try it!![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![DSCF4435.JPG DSCF4435.JPG](https://www.electro-tech-online.com/data/attachments/51/51740-c79a4f7df4726b5cf91ca80d7046acf2.jpg)
![DSCF4436.JPG DSCF4436.JPG](https://www.electro-tech-online.com/data/attachments/51/51741-affe503c30914c6316c5fb1cc5b5daaa.jpg)
![DSCF4437.JPG DSCF4437.JPG](https://www.electro-tech-online.com/data/attachments/51/51742-e7e9002e21ff4f2377b13a28f46e2a8e.jpg)
Module specs:-
*) Audio mute
