for loop error when programming with dsPIC v3_20b programmer
Cantafford
Hello. I'm playing with a dsPIC30F2010 and I wanted to make a led blink. I wrote this code:
#include <stdio.h>
#include <stdlib.h>
#include "header.h"
void main()
    TRISB = 0;
    while(1)
        LATBbits.LATB0 = 1;
        for(int delay=0; delay<2; delay++) __delay_ms(5);
When I run this code I get the following error:
main.c:19: error: 'for' loop initial declaration used outside C99 mode
I tried initialising the 'delay' variable outside the loop. Still get that error.
When I program PIC's, not dsPIC's and I write such a loop to get a delay I don't get that error. I only get it when I'm using the dsPIC programmer. Any ideea why? Thanks for reading.
Hello, thanks for answering
Well thus far I have been using it like that and got no errors(I've seen it in a tutorial). I even tested with a program that I wrote for PIC18f2550 and it worked fine. I'm guessing it's included in stdio or stdlib.
In header.h I have: "#define __XTAL_FREQ 8000000" if that's what you mean by defining a frequency.
The dspPic range use the C30 compiler.... I don't think it uses that syntax...
The __delay_ms() was defined in the pic.h on the HTC compiler.. If you loose the for loop and just write the delay instruction... What does the compiler say!!
They want this:
C:
        int delay;
        for(delay=0; delay<2; delay++) __delay_ms(5);
For the delay to work, you need to define something of that sort:
C:
#define FOSC (7370000ULL)
#define FCY (FOSC/2) // if you have one of obsolete dsPIC30, it's FOSC/4 for most of them
It says:
undefined reference to `___delay_ms'
They want this:
C:
        int delay;
C:
So I just include them in my header file and it should work? Shouldn't I include a library that has the __delay_ms() function? I don't understand :D
In your header write a delay function that will cover all
C:
void delayUs(int x)
    x>>= 5; // change to  4, 3 or 2 to suit OSC
    while(x--);
void delayMs(int x)
    while(x--)
       delayUs(1000);
Then you can specify any delay!!
They want this:
C:
        int delay;
NorthGuy has the correct answer. This error:
is basically saying that you can't declare an int within the for loop. You need to declare the int externally (before the for loop):
C:
        int delay;
Had a bit of a tussle with this and PIC24EP For these delays with XC16 ,
#define FCY 8000000UL       // instruction cycle  16M osc
#include <libpic30.h>
// libpic30 delays
#define __delay_ms(d) \
  { __delay32( (unsigned long) (((unsigned long long) d)*(FCY)/1000ULL)); }
#define __delay_us(d) \
  { __delay32( (unsigned long) (((unsigned long long) d)*(FCY)/1000000ULL)); }
Then use as __delay_ms(250) ; etc.
