ukiltmybrutha
I have a 2002 Ford Excursion where the VSM (Vehicle Security Module) died. The basic resultant issues were:
1) No power door locks.
2) Door Ajar light.
The VSM is no longer made and no longer repaired (not by any place that I trust anyways).
If you buy a used VSM they are quite a bit of money and must be reprogrammed by the dealer for about $380 or so. Most dealers I called are of the mindset that I just get a new truck. Well no way, this truck is new to me and now I know why the last person got rid of it.
I reflowed the solder on the main connectors but to no avail.
So I did the next best thing. I went on Ebay and got myself a used one. To my delight (sort of) the used VSM worked with one major issue.
The door switches only turn the interior lights on when the front doors are open. Basically, the ECM I purchased used belonged to a truck.
Now on a smaller sedan I might be able to get by with the rear interior lights not working when the door is opened. However on a vehicle this big it is not too fun in the 2nd, 3rd, and cargo area to be opening doors with no resultant interior lights.
So I grabbed myself a wiring diagram and found that the main dimmer switch allows all of the interior lights to come on when a ground signal is received. That circuit then goes through the instrument cluster where there is an internal relay.
That gave me a bright idea. I have the pinouts for the VSM and know which pins/wires are connected to the VSM via the rear door switches. Real easy access!
The only issue that I have is that door switches send a ground signal when the door is shut. In that scenario, the interior lights come on when the rear doors are shut which is exactly opposite of what I want.
Is there anything simple that I can do to force a ground signal to the main dimmer switch? I don't want to do anything invasive since the door switches are a nightmare to access and want to leave what is working well alone.
A relay for each door switch? Would that work? Anything simpler?
Thanks for any ideas.
2) Door Ajar light.
