Hi Guys,
I have a Dell Inspiron 530, it's about 4 years old, got a dual core processor, the pc suddenly died the other day with no warning, I have diagnosed the 4 pin ATX processor power connector that stops the system running.
Upon further investigation I took everything off (including CPU) and found there was a short between the 12V and 0V on the 4 pin ATX (not on the 20 Pin ATX), which is shunting the PSU.
Dell being "special", only parts which fit are Dell only, and are obsolete. Yay!![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have checked for obvious signs of burning or anything slightly brown, nothing jumps out at me, I have the motherboard out under the microscope to see if I can see anything, still nothing.
What is the likely hood that replacing the 1500uF caps around that power supply will resurrect it? I don't have any rated to that so I would have to buy some, normally I would just replace the thing, but they are not easy to get hold of.
Unless anybody else has any other suggestions?
None of the caps have their tops raised or are leaking, but that's the only thing I can think that would short the 12v to 0v, there are about 6/8 mosfets around the PSU circuit also.
Thanks!
Wilksey
Thanks!
Wilksey
