FPGA Troubleshooting
TerryC03
I'm having difficulties troubleshooting a possible unintended latch. The board I'm testing with is an Altera DE2-115. I'm using the platform designer and the VHDL code that I had to enter was just the component and ports:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity de2_test_proj is
port(
    clock_50: in std_logic;
    reset: in std_logic;
    gpio: out std_logic_vector(1 downto 0); -- Access to GPIO(0 - 1)?
    ledr: out std_logic_vector(1 downto 0);
    sw: in std_logic_vector(1 downto 0);
    --hex0, hex1, hex2, hex3: out std_logic_vector(7 downto 0);
    lcd_data: inout std_logic_vector(7 downto 0);
    lcd_blon: out std_logic;
    lcd_on: out std_logic;
    lcd_en: out std_logic;
    lcd_rs: out std_logic;
    lcd_rw: out std_logic
end entity;
architecture behavioral of de2_test_proj is
    component de2_proj is
        port (
            clk_clk                                 : in    std_logic                    := 'X';             -- clk
            gpio_pio_external_connection_export     : out   std_logic_vector(1 downto 0);                    -- export
            led_pio_external_connection_export      : out   std_logic_vector(1 downto 0) := (others => 'X');                    -- export
--                hex0_pio_external_connection_export     : out   std_logic_vector(7 downto 0);                    -- export
--            hex1_pio_external_connection_export     : out   std_logic_vector(7 downto 0);                    -- export
--            hex2_pio_external_connection_export     : out   std_logic_vector(7 downto 0);                    -- export
--            hex3_pio_external_connection_export     : out   std_logic_vector(7 downto 0);                     -- export
            reset_reset_n                           : in    std_logic                    := 'X';             -- reset_n
            sw_pio_external_connection_export       : in    std_logic_vector(1 downto 0) := (others => 'X'); -- export
            character_lcd_0_external_interface_DATA : inout std_logic_vector(7 downto 0) := (others => 'X'); -- DATA
            character_lcd_0_external_interface_ON   : out   std_logic;                                       -- ON
            character_lcd_0_external_interface_BLON : out   std_logic;                                       -- BLON
            character_lcd_0_external_interface_EN   : out   std_logic;                                       -- EN
            character_lcd_0_external_interface_RS   : out   std_logic;                                       -- RS
            character_lcd_0_external_interface_RW   : out   std_logic                                        -- RW
    end component de2_proj;
begin
    u0 : component de2_proj
        port map (
            clk_clk                                 => clock_50,                                 --                                clk.clk
            gpio_pio_external_connection_export     => gpio(1 downto 0),     --       gpio_pio_external_connection.export
            led_pio_external_connection_export      => ledr(1 downto 0),      --        led_pio_external_connection.export
--                hex0_pio_external_connection_export     => hex0(7 downto 0),     --       hex0_pio_external_connection.export
--            hex1_pio_external_connection_export     => hex1(7 downto 0),     --       hex1_pio_external_connection.export
--            hex2_pio_external_connection_export     => hex2(7 downto 0),     --       hex2_pio_external_connection.export
--            hex3_pio_external_connection_export     => hex3(7 downto 0),      --       hex3_pio_external_connection.export
            reset_reset_n                           => '1',                           --                              reset.reset_n
            sw_pio_external_connection_export       => sw(1 downto 0),       --         sw_pio_external_connection.export
            character_lcd_0_external_interface_DATA => lcd_data(7 downto 0), -- character_lcd_0_external_interface.DATA
            character_lcd_0_external_interface_ON   => lcd_on,   --                                   .ON
            character_lcd_0_external_interface_BLON => lcd_blon, --                                   .BLON
            character_lcd_0_external_interface_EN   => lcd_en,   --                                   .EN
            character_lcd_0_external_interface_RS   => lcd_rs,   --                                   .RS
            character_lcd_0_external_interface_RW   => lcd_rw    --                                   .RW
end architecture;
I commented out the 7-segs (hex) because the issue is causing the ledr14 to go out unintentionally; this is the issue I'm having. Is it the code, or possibly the .qsys file?
Come to find out, it was both the .qsys file and the VHDL code. The bit width was larger than I needed for the 7-segment displays; I didn't use all of the required bits. I changed the components within the platform designer from 7 bits, to 6. For those who want to see the changes:
library ieee;
port(
    hex0, hex1, hex2, hex3: out std_logic_vector(6 downto 0);
end entity;
        port (
            led_pio_external_connection_export      : out   std_logic_vector(1 downto 0) := (others => '1');                    -- export
                hex0_pio_external_connection_export     : out   std_logic_vector(6 downto 0);                    -- export
            hex1_pio_external_connection_export     : out   std_logic_vector(6 downto 0);                    -- export
            hex2_pio_external_connection_export     : out   std_logic_vector(6 downto 0);                    -- export
            hex3_pio_external_connection_export     : out   std_logic_vector(6 downto 0);                     -- export
begin
        port map (
                hex0_pio_external_connection_export     => hex0(6 downto 0),     --       hex0_pio_external_connection.export
            hex1_pio_external_connection_export     => hex1(6 downto 0),     --       hex1_pio_external_connection.export
            hex2_pio_external_connection_export     => hex2(6 downto 0),     --       hex2_pio_external_connection.export
            hex3_pio_external_connection_export     => hex3(6 downto 0),      --       hex3_pio_external_connection.export
end architecture;
