free electronic circuit simulator
LTSpice
I have posted hundreds of running LTSpice circuit simulations on these forums (and others).
I also use LTspice.
It's probably one of the best free circuit simulators available.
It has a somewhat steep learning curve, but it's well worth the effort if you are designing circuits and/or learning about electronics.
It finds a lot of circuit errors before you built your breadboard.
LTspice has some good tutorials and many sample circuits to help you get started.
I third the LTspice suggestion.
Fourth.
Just keep in mind that you will likely need to create a lot of models yourself, or at the very least import them from third-party sources. By default LTSpice mostly only contains Linear Technology components and a few other standard parts. But chances are you'll need to import your own models for a lot of circuits.
i have a nice ltspice constant power load here...
  • Constant power load_386W.asc
Also here is a useful voltage controlled switch, for when you want your sim to turn something on or off at a specific time
  • Voltage controlled switch.ASC
and some quik start guides
  • LTspice _Quick Start Guide.doc
  • LT wiki.doc
just get into it and start your sim.....dont be like me and be afraid of starting it because you somehow convince yourself that the PC will blow up if i mis-wired something
Fourth.
I attended the Del Mar Electronics show this week. There was an Analog Devices/ Linear Tech booth. I asked about LTspice and the convergence of AD parts with LTC parts. I was informed this was in the works. This convergence should add a large amount of component coverage in LT Spice which will make this free tool just the more valuable :)
