Hi All,
I'm working on a project using the SSB method to shift a band of frequencies. I'm considering both the "Phasing" and "Weaver" methods. For the phasing method, I'm using an HEF4013 dual D flip-flop and the Hc4066 analog switch to modulate an incoming sine wave. I'm totally confused about the Vdd supply which can from 5 - 15 V and gives better mark-to-space ratios for higher supply. If i do use 15V , how can i connect it to the 4066 which only accepts max +5 V? I am using a Pico ADC 212 spectrum analyzer also, and on mixing a 40 khz sq signal from the hef4013, with a 50khz sine signal, i get significant signals at 20khz,60khz, 70khz which i cannot explain (and i have ruled out aliasing). Is this some second harmonic distortion from the flip flop square wave? Is there any better quadrature circuit or switch i can use to improve this? I had the entire phasing circuit set up sometime ago, using an opamp (LM318) as the final summing stage, but could not adequately reject the unwanted sideband. I'm really at my wits end as how to proceed from here Please please help!!
