allaccess
Please ignore/delete this thread. Problem fixed. Sorry for the inconvenience.
Is it possible for an LM324 to be damaged in such a way as all 4 op-amps still amplify but such a basic circuit fails?
Hello, I am trying to use an LM324 quad op-amp to build a basic function generator but i suspect the chip may be damaged.
When i perform a simple can-it-amplify test, all four op-amps pass: I attach a crystal earpiece to the +input, and an 8ohm speaker and a green LED to the output, and simply tap on crystal earpiece, and i get an audible click from the speaker and a flash from the LED when I perform this test on all 4 op-amps.
However, i have tried multiple google-search function generator circuits and none of them work. I get no square wave, and no reading on my digital scope, including this circuit:
Is it possible for an LM324 to be damaged in such a way as all 4 op-amps still amplify but such a basic circuit fails? I have tried constructing just the 1st stage and still get no square wave or output of any kind on pin 1.
Thanks, allaccess
![Function-generator-circuit.png](https://www.learningaboutelectronics.com/images/Function-generator-circuit.png)
Thanks, allaccess
