from a 16f628 to a pic18f1230 lcd code.
tracidfish
Hi
I am trying to drive an LCD in 4 bit mode using a pic18f1320.
I am satisifed that my hardware is correct, but I cannot get it to work. All I get is the balck squares. I have had a similar piece of code working on a pic 16 but would like to use in a pic 18.
I am trying to use an internal oscilator with no clock out and no mclr.
Can any one see where I have gone wrong?
thanks
Charlie
        include <P18F1320.INC>
;Configuration bits
;      __CONFIG    _CONFIG1H, _IESO_OFF_1H & _FSCMEN_OFF_1H & _INTIO2_OSC_1H
;      __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _BORV_20_2L
      __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_32_2H
      __CONFIG    _CONFIG3H, _MCLRE_OFF_3H
;      __CONFIG    _CONFIG4L, _BKBUG_OFF_4L & _LVP_OFF_4L & _STVR_OFF_4L
      __CONFIG    _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
      __CONFIG    _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
      __CONFIG    _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
      __CONFIG    _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
      __CONFIG    _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
      __CONFIG    _CONFIG7H, _EBTRB_OFF_7H
		cblock	0x80			;start of general purpose registers
			count			;used in looping routines
			count1			;used in delay routine
			counta			;used in delay routine
			countb			;used in delay routine
			tmp1			;temporary storage
			tmp2
			tmp3
			templcd			;temp store for 4 bit mode
			templcd2
			offsetL			;table registers
			offsetH
			offsetL1
			offsetH1
			seconds
			minutes
			hours
		endc
LCD_PORT	Equ	PORTA
LCD_TRIS	Equ	TRISA
LCD_RS		Equ	0x04			;LCD handshake lines
LCD_RW		Equ	0x06
LCD_E		Equ	0x07
;Reset Vector
ResetVector     CODE    0x00
;Initialize I/O pins
        movlw   B'01110000'          ;Select 8MHz frequency  (B'01110000')PAGE 19
        movwf   OSCCON				 ;Select 4MHz frequency  (B'01100000')
; INITIALIZE PORTS
SetPorts
		movlw	0x00			;make all pins outputs
		movwf	LCD_TRIS
		call	Delay100		;wait for LCD to settle
		call	LCD_Init		;setup LCD
;WELCOM
messgae
	call	LCD_Clr
	call	LCD_Line1
	movlw	'W'
	call	LCD_Char
	movlw	'E'
	call	LCD_Char
	movlw	'L'
	call	LCD_Char
	movlw	'C'
	call	LCD_Char
	movlw	'O'
	call	LCD_Char
	movlw	'E'
	call	LCD_Char
	movlw	'.'
	call	LCD_Char
	movlw	'T'
	call	LCD_Char
	movlw	'O'
	call	LCD_Char
	call	LCD_Line2
	movlw	'D'
	call	LCD_Char
	movlw	'I'
	call	LCD_Char
	movlw	'V'
	call	LCD_Char
	movlw	'E'
	call	LCD_Char
	movlw	'.'
	call	LCD_Char
	movlw	'B'
	call	LCD_Char
	movlw	'U'
	call	LCD_Char
	movlw	'D'
	call	LCD_Char
	movlw	'Y'
	call	LCD_Char
	movlw	'Y'
	call	LCD_Char
	call	Delay255
	call	Delay255
	call	Delay255
	call	Delay255
goto messgae
;Initialise LCD
LCD_Init	movlw	0x20			;Set 4 bit mode
		call	LCD_Cmd
		movlw	0x28			;Set display shift
		call	LCD_Cmd
		movlw	0x06			;Set display character mode
		call	LCD_Cmd
		movlw	0x0d			;Set display on/off and cursor command
		call	LCD_Cmd
		call	LCD_Clr			;clear display
		retlw	0x00
; command set routine
LCD_Cmd		movwf	templcd
		swapf	templcd,	w	;send upper nibble
		andlw	0x0f			;clear upper 4 bits of W
		movwf	LCD_PORT
		bcf	LCD_PORT, LCD_RS	;RS line to 0
		call	Pulse_e			;Pulse the E line high
		movf	templcd,	w	;send lower nibble
		movwf	LCD_PORT
		call 	Delay5
		retlw	0x00
LCD_CharD	addlw	0x30
LCD_Char	movwf	templcd
		movwf	LCD_PORT
		bsf	LCD_PORT, LCD_RS	;RS line to 1
		movwf	LCD_PORT
		call 	Delay5
		retlw	0x00
LCD_Line1	movlw	0x80			;move to 1st row, first column
		call	LCD_Cmd
		retlw	0x00
LCD_Line2	movlw	0xc0			;move to 2nd row, first column
		call	LCD_Cmd
		retlw	0x00
LCD_Line1W	addlw	0x80			;move to 1st row, column W
		call	LCD_Cmd
		retlw	0x00
LCD_Line2W	addlw	0xc0			;move to 2nd row, column W
		call	LCD_Cmd
		retlw	0x00
LCD_CurOn	movlw	0x0d			;Set display on/off and cursor command
		call	LCD_Cmd
		retlw	0x00
LCD_CurOff	movlw	0x0c			;Set display on/off and cursor command
		call	LCD_Cmd
		retlw	0x00
LCD_Clr		movlw	0x01			;Clear display
		call	LCD_Cmd
		retlw	0x00
Delay255	movlw	0xff		;delay 255 mS
		goto	d0
Delay100	movlw	d'100'		;delay 100mS
		goto	d0
Delay50		movlw	d'50'		;delay 50mS
		goto	d0
Delay20		movlw	d'20'		;delay 20mS
		goto	d0
Delay5		movlw	0x05		;delay 5.000 ms (4 MHz clock)
d0		movwf	count1
d1		movlw	0xC7			;delay 1mS
		movwf	counta
		movlw	0x01
		movwf	countb
Delay_0
		decfsz	counta, f
		goto	$+2
		decfsz	countb, f
		goto	Delay_0
		decfsz	count1	,f
		goto	d1
		retlw	0x00
Pulse_e		bsf	LCD_PORT, LCD_E
		nop
		bcf	LCD_PORT, LCD_E
		retlw	0x00
	END
