From SMD tactile switch to 4 pin connector
georgeflr
Hello,
I have a LCD Board for a Raspberry Pi and it has a few pushbuttons on the side. They are SMD tactile switches.
I want to move them into a separate location, either a PCB Board or a mounting place.
My question is that if I cand find compatible connectors, that can pe soldered on the old pushbuttons pads and not leaving soldered wires directly on the old pads. This way I can connect the buttons and disconnect them as I please.
Thank you.
Pads might not be robust enough to support robust actions, let alone the SMD switches. If this is a serviceability, reliability issue, you need to define the requirements better and design to meet them.
