Theoretically yes. However it will most likely be a volt or so less due to the forward voltage drop across the diodes.If this is so would I see 169VDC if i full wave bridge rectify 120VAC?
Hi:
When I use a fullwave bridge on an AC voltage of 6.3V I get close to 9VDC. Which I suppose is the effect of RMS on the AC sine wave.
If I were to have 12 , 14VDC loads that i want to run from the mains.....in series, can I place the smoothing caps across each of the loads....12 caps rated at 25VDC?
Or do i have to have like a 200VDC cap across the rectified mains?
hi, i have a project on analab 2.0. my instructor ask me to make a hardware for a stepper motor and plug it in the system bus of analab 2.0.my problem is i don't know how to get the i/o address of the system bus.please help.
You should do that Google search yourself.No, that is not a good idea. First do a Google of Caps in series. You will find that the capacitance of caps in series is calculated the same way resistors in series is calculated, so what happens to C total.
You should do that Google search yourself.Caps in series are calculated the same as resistors in parallel. Caps in parallel are calculated the same as resistors in series.
If you run loads in series, then each load has to take exactly the same current.If I were to have 12 , 14VDC loads that i want to run from the mains.....in series, ...
Yes, each load will see it's own 1000uF cap.If we have 12 loads in series of all equal resistance. Pulling about 3 Amps with a voltage drop of 14VDC each with a 1000uf Cap across each shouldn't each load see the full 1000uF at 14VDC smoothed?
