Function block programming for PIC18F
Hi Steffen
Had some time to look at the eeprom writing. These function blocks are included in VPS_P18 versions 2.01 and 2.02 I have attached two files, the one is the document describing the eeprom read and write blocks, the .txt file is a project file you can run on the simulator and see how the reading and writing works. For the .txt file you must change the extention .txt back to .lcb before you can use it with VPS.
  • FBlock45_52Description.pdf
  • EE_Test.txt
