Im relatively new to C programming and have been following books and online tutorials but i cant find an answer any where.
Ive written a program to adjust the brightness of an LED, when you hold switch RA4 the program goes to a function to adjust the PWM value "green_val" eveerything works as it should in the function but when I return to the main program the "green_val" registry returns to 0 rather then what it was set to in the function.
C:
#include <stdio.h>
#include <stdlib.h>
#include "pic16f874a_Config.h"
#include "lcd.h"
#include "pic16f874a.h"
#include "delays.h"
#define duty 1
void main(void)
* configure CCP module as 4000 Hz PWM output
PIR1 =255;
T2CON =0b00000101 ;
CCP1CON =0b00001100 ; //Configure PWM Mode, Set DB bits to 10
CCPR1L =0b00000000 ; // reset to zero
Init_Pic();
lcd_init();
RC0=1;
unsigned int green_val;
for(;;)
CCPR1L = green_val;
lcd_goto(0);
lcd_puts("green_val1");
if(RA4 == 0)
lcd_clear();
Set_Green(green_val);
unsigned int Set_Green(unsigned int green_val)
lcd_goto(0);
lcd_puts("Green");
while(RA4 == 0)
{ // digital adjustment of duty cycle
if(RA5 == 0)//Brightness up
if(green_val == 255)
else
green_val++;
lcd_goto(0x40);
lcd_putch(green_val);
__delay_ms(50);
if(RE0 == 0)//Brightness down
if(green_val == 0)
else
green_val--;
lcd_goto(0x40);
__delay_ms(50);
CCPR1L = green_val;
lcd_clear();
return green_val;
