DOO EET is "do it".What do you mean by doo eet?
The IR2113 provides bootstrapping for the upper N-channel Mosfet and a much higher supply voltage can be used for it if you want. Without bootstrapping then the upper Mosfet might not ever turn on if the supply voltage is low or if the supply voltage is high it will not turn on enough. You could make the complicated circuit yourself that is already inside an IR2113 IC.What's the difference between direct switching and switching through IR2113?
