I am trying to get a better understanding of magnetic induction. Lets say you have an electromagnet wrapped around an iron rod (primary coil). On the other end of the rod you have another coil(secondary) hooked up to a meter. If you simply pulsed the primary coil with DC would this produce a lower voltage in the secondary coil if instead you instead ran AC through the primary coil?
