sword_fighter
I need to generate a square wave pulse using 555timer...which has a maximum output voltage 5volt & minimum output voltage 1.4volts...and on time 60sec & off time 90sec...
I used astable circuit for making this particular pulse....but the minimum value is always coming to 0v instead of 1.4volts.....so i thought to use biased series clipper to make the minimum value 1.4volts....but i dnt have any value of that load resistor....so guess help me...how can i generate this square pulse using 555timer
