Cantafford
Hello,
I have connected 2 ATMEGA328P's with SPI communication one as master one as slave. On the master MCU I have also attached a keypad. I want to read a key from that keypad and send it via SPI to the slave. I will use a test-led which will light up when the value of the key pressed is 0. I have tested the interfacing of the keypad. It works fine.
Should be simple however I cannot seem to be able to send the value of the key pressed. I have managed to send data which I write in code but when I press a key the data does not reach the slave device for some reason.
Here is the code for the master:
And here is the code for the slave device:
Here is how I connected everything. Based on my code whenever I press keypad(1) the LED should light up. However the LED is off at all times.
Please help me correct this. Thank you.
* SPI.c
* Created: 2/18/2017 10:09:10 AM
* Author: Paul
#define F_CPU 8000000
//SPI master
#include <avr/io.h>
#include <stdlib.h>
#include <util/delay.h>
#include <avr/interrupt.h>
void SPIMasterInit(void);
void SPIMasterSend(int key);
int GetKeyPressed();
int main(void)
//SPIMasterInit();
int key;
while (1)
key=GetKeyPressed(); // key gets read properly
SPIMasterSend(key); // send the read value of the key!!!
//SPI init
//set MOSI, SCK and SS as output
DDRB |= (1<<PB3)|(1<<PB5)|(1<<PB2);
//set SS to high
PORTB |= (1<<PB2);
//enable master SPI at clock rate Fck/16
SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR0);
//master send function
//select slave( SS must be pulled to ground before sending data )
PORTB &= ~(1<<PB2);
//send data(=1)
SPDR=key; // this is the data sent!!!!
//wait for transmition complete
while (!(SPSR &(1<<SPIF)));
//SS to high
PORTB |= (1<<PB2);
int GetKeyPressed()
int r,c;
PORTD|= 0X0F;
for(c=0;c<3;c++)
DDRD&=~(0X7F);
DDRD|=(0X40>>c);
for(r=0;r<4;r++)
if(!(PIND & (0X08>>r)))
return (r*3+c);
return 0XFF;//Indicate No key pressed
* slave.c
* Created: 2/18/2017 10:48:09 AM
* Author: Paul
//SPI slave
#include <avr/io.h>
#include <stdlib.h>
#include "lcd.h"
#include "myutils.h"
void SPISlaveInit(void);
void InitLCD();
ISR(SPI_STC_vect)
uint8_t recievedData;
recievedData = SPDR;
if(recievedData == 0) PORTB |= (1<<0);
int main(void)
int key;
DDRB |= (1<<0); // check led set as output
InitLCD();
sei();
while (1)
//set MISO as output
DDRB |= (1<<PB4);
//enable SPI and enable SPI interrupt
SPCR = (1<<SPE)|(1<<SPIE);
void InitLCD()
LCDInit(LS_NONE|LS_NONE);
LCDClear();
LCDWriteString("Test text ");
_delay_ms(150);
LCDClear();
![9ixv6e.jpg](https://i65.tinypic.com/9ixv6e.jpg)
