Hi..
Below is the code to generate 4kHz sine wave using PWM for PIC18F4620. I am going to test it soon but at the mean time, i don't have the equipment such as oscilloscope so am not able to test it jst yet.. However, by simulating it in Proteus, I am able to see the pulsewidth (or duty cycle changes accordingly). The PWM output will connect to sallen key's 2nd order low pass filter with a cut off frequency of 4kHz or slightly higher so that the higher frequency will be filtered off leaving behind a sine wave (hopefully).
I am in the middle of building a low pass filter similar to the low pass filter of this preamp.
Anybody done this before..? Please advice..
Thanks..
Thanks..
#include <p18f4620.h>
#include <delays.h>
#include <usart.h>
#include <stdio.h>
#include <timers.h>
#include <pwm.h>
#pragma config OSC=HSPLL
#pragma config PWRT=ON
#pragma config BOREN=OFF
#pragma config WDT=OFF
#pragma config MCLRE=ON
#pragma config PBADEN=OFF
#pragma config LVP=OFF
#pragma config XINST=OFF
#define CLOCK_FREQ (40000000) // Hz
// FUNCTION PROTOTYPE
void low_isr();
void InitInterrupt();
void InitTimer2();
void InitPWM();
void UpdateDutyCycle();
// GLOBAL VARIABLE
unsigned int cnt8000 = 0;
char cntDty = 0;
char boolUpdateDty = 0;
const unsigned char Dty [24] = {128, 160, 191, 218, 238, 251, 255, 251, 238, 218, 191, 160, 128, 95, 64, 37, 17, 4, 0, 4, 17, 37, 64, 95}; // Testing
unsigned long int tempDty1 = 0, tempDty2 = 0;
// SETUP ISR VECTOR
#pragma code low_vector=0x18 //setup the ISR vector
void low_interrupt (){
_asm GOTO low_isr _endasm //jump to interrupt handler
#pragma code
// ISR
#pragma interruptlow low_isr //the ISR
void low_isr()
if (PIR1bits.TMR2IF == 1)
PIR1bits.TMR2IF=0;
boolUpdateDty = 1;
if (cnt8000 < 8000)
cnt8000++;
else
cnt8000 = 0;
#pragma code
void main()
InitInterrupt();
InitTimer2();
InitPWM();
T2CONbits.TMR2ON = 1;
while (1)
if (boolUpdateDty==1)
boolUpdateDty = 0;
UpdateDutyCycle();
PIE1bits.TMR2IE = 1; //enable Timer2 interrupt
INTCONbits.PEIE = 1; //enable peripheral interrupts
INTCONbits.GIE = 1; //enable glogal interrupts
IPR1bits.TMR2IP = 0; // low priority
void InitTimer2()
T2CON = 0b01001000;
PR2 = 124; // 125 counts including 0
void InitPWM()
SetDCPWM1(250);
CCP1CON=0b00001100; //ccpxm3:ccpxm0 11xx=pwm mode
T2CONbits.TMR2ON = 0; // STOP TIMER2 registers to POR state
PR2 = 124;
if ((cnt8000%334)==0)
tempDty1 = 50000/255;
tempDty2 = Dty[cntDty]*tempDty1/100;
SetDCPWM1(tempDty2);
if (cntDty < 22)
cntDty++;
else
cntDty = 0;
