magician13134
So, I made an Eagle file of a PCB, and I want to etch it myself, it's single sided, how can I turn that into a black and white image to etch a cricuit board with? Thanks
magician13134 said:So, I made an Eagle file of a PCB, and I want to etch it myself, it's single sided, how can I turn that into a black and white image to etch a cricuit board with? Thanks
magician13134 said:Oh, so I just print it out, and that'll be right? Thanks
magician13134 said:I DON'T MIRROR IT?! WHAT?! Are you POSITIVE about that?!
Ooh, yeah... I guess that's going on the bottom... so I guess you're right. Wow, I NEVER would have caught that... Thanks very much!
3v0 said:Yup, quite positive.Or you can just mount the transistors backwards and bend all the IC pins 180 degrees.
theinfamousbob said:The stuff I used needed to be mirrored. Then again I was looking at the bottom of the board. I guess top view wouldn't need to be mirrored.
You will always need to check the mirror box when transfering to the top side of the board.mvs sarma said:Perhaps we have to follow the rule as per the package we use.
3v0 said:You will always need to check the mirror box when transfering to the top side of the board.
How can that be different for different products?
