If you connect a load of the emitter side (in series with emitter resistor) the load will affect the current drawn. The only case this is acceptable is if the load has a constant resistance, or is much smaller than the emitter resistor: in the former case the current will remain constant, in the latter, it will not change much.what if i tap my load in the emitter side that can be my Vout and Iout?..ive checked in the multisim and it gives me sufficient output![]()
thanks guys
how can i maintain a current if no R2 in the circiut or no load?
You cannot with that circuit
i tested it on multisim i remove the R2 in the circiut and it gives me 0A
It would the transistor is OFF
how can i make a same current like 200mA with R2 and 200mA with NO R2 in the circuit?
You cannot , R2 sets the 200mA
200mA a sample current rating from the circuit
is there any adjustments in the circiut that i can make to make it possible?
i am making a simple supply with no use of regulators that can be inputed by 6v-9v and will regulate a 5.1v w/ a current of 200mA ..and there are two conditions
a)w/ load-R2 is not remove
b)no load-R2 is remove or short circiut
Errmm...My favorite constant current device (CRD) is a jfet
