justDIY
Active Member
I have a 5x7 array that I'm scanning (strobing?) one column at a time (5 columns, 7 rows). Unless I scan the columns very slowly, I have adjacent leds also illuminating. At moderate speed, such as 1ms per column, the adjacent leds (that should be completely off) are dimly visible. At 400uS per column, they're almost as bright as the leds that should be on.
You can see the schematic and board layout here:
https://projects.dimension-x.net/archives/101
I'm trying out a new high level language "mikrobasic". so far I like it a lot better than proton, but it takes a little getting used to.
Here is the code with which I update the led display:
ledrow is a symbol for porta, ledcol is a symbol for portb, mydelay is current defined as "1" (milliseconds)
the pic is a 16f737, running at 8mhz on the internal osc.
the matrix is anode column, cathode row. the pic sinks current, and the anodes are driven by five p-ch mosfets
any ideas on stopping the ghosting, or at least what's causing it?
sub procedure DisplayChar()
X = 0
While X < 5
LEDROW = 255 XOR MyChar[x] ' load a row with data
MyCol = 1 << X ' select a column
LEDCOL = 255 XOR MyCol ' light up the column
Delay_MS(MyDelay)
Inc(X) ' next column
Wend
end sub
