Guys, i have lots of question regarding relays and transistors
Ralphgreg
Can you tell me the difference between a relay and transistor as a switch?
What are the advantages and disadvantages of relays?
One big difference is that the relay will wear out and stop working long before the transistor will, in most cases.
By using a relay you can switch things on and off while the control circuit remains electrically isolated.
Relays can switch either AC or DC loads with either a AC or DC signals and are electrical/magnetic/physical devices. They're great specifically for using small (but not nearly as small as a transistor) signals to switch higher powered AC or DC loads. Relays are highly reliable but mechanical and limited in switching cycles and prone to mechanical failure towards the end of their life or if abused.
Transistors switch DC current ONLY with applied DC voltages ONLY, and have many advantages and disadvantages compared to a relay.
Your question is difficult to answer unless you state the particular application you're interested in, an overall view would be problematic because there are so many different advantages and problems in various situations, in some case a relays is cheap and perfect, in others it simply wouldn't be possible to use one.
Sorry to interrupt (and compound the question) but aren't solid state relays without mechanisms?
No, their mechanism is however the change in the conduction state of a material based on nearby electric field potentials, not physically moving objects slapping conductors together. The original poster however was not talking about solid state relays which are entirely different altogether. He was asking specifically about the transistor vs a mechanical relay. At least that's how I read it, I would hope the poster would correct me if I'm wrong in that reading.
