When the PIC output goes high to +5V then the emitter of the TIP122 goes to only +2.8V. Both TIP127 darlingtons will be turned on ALL THE TIME since their inputs must be +12V to turn them off!
If i connect them as shown in the attached diagram, will it work? Instead of supplying 5V, the PIC is driving two bc546 which will supply the TIP122 and the TIP127 with 12v at their base.
You should use Mosfets (they have a very low voltage loss).
I'm not familiar with PICs, but if their output is only +5, will they get the FETs turned on? And is a 74 amp FET a good choice? I think not, do some digging and you'll find some better matches to you project.
Kinarfi
