gramo
I just finished a basic example for a Hall Effect sensor (Allegro's A1102), and have a question about sample speeds
More about the programming/circuit can be found **broken link removed**
The datasheet specifies that a nominal load of 820ohms @12V for 400nS rise and fall times. Does this mean I can get the same results for a 5V supply with a ~330ohm resistor? (Decreasing the resistance to match current)
I don’t have a device that would mechanically spin fast enough to test 400nS rise/fall times, if I did, I'd try it out with that![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
