Hello,
Just got a question.
We all know that in a SSB modulator the bandwidth and power of transmission is reduced by half than when using AM-DSB. I read that it is becuase we do'nt have one of sidebands in SSB. But What which is confusing to me is that, the load has a CONSTANT impedance when connected to the the output modulator (whether DSB or SSB is used). Suppose the load is 10 ohms (these values are imaginary an maybe do not exist is real). now for instance if a modulator used as a SSB modulator will produce a maximum of voltage less than when used as DSB modulator for the said load so that the power happens to be halved?
Saying the RMS power of a DSB modulator is 10W for the said load now:
Vrms=(PxR)^1/2 =10V
Now the said modullator would produce halved output power if uses as SSB:
Vrms=(5x10)^1/2 =7.07V
Now it seemsthat removing one sideband causes to output volatge to drope and cause the ouput power to be halved in SSB than DSB ,right?
If you are agreed with me till now, SO plaese is there somebody to explain me why removing one side band causes the output voltage to drope?
And while the load is constant to a SSB transmitter by the said properties or values, do I need to incases the output voltage so that improve and recover the original power than DSB, While the SSB modulator is used as a transmitter, or its better to reduce the load so that get the original power, Or I do not need to do any thing and confused myself by something?
Thanks for any help
Vrms=(PxR)^1/2 =10V
Thanks for any help
