Space Varmint
He conquered, "Death, Hell & the Grave". ![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
And to you also. That's what it's all about.
Happy Easter to you too.
Tucker GA?.......I was there once many years ago.....had great moonshine!
LOL, yeah I might pick up some Ever Clear from time to time. Strickly for medicinal purposes....you know.
Thanks & back atchya
A common distillation with an azeotrope is the distillation of ethanol and water. Using normal distillation techniques, ethanol can only be purified to approximately 96% (hence the 96% (192 proof) strength of some commercially available grain alcohols).
Once at a 96.4% ethanol/water concentration, the vapor from the boiling mixture is also 96.4%, therefore further distillation is ineffective. Some uses require a higher percentage of alcohol, for example when used as a gasoline additive. The 96.4% azeotrope needs to be "broken" in order to refine further.
You could certainly get drunk into a full stupor, have the kind of fun in the process that attracts Officer John Law after you, and thereby convicted in a court of law and then sentenced to die by crucifiction. Now there, you'd have all your eggs in one basket!![]()
