Krumlink
I am going to tell you my HCL story, from 7th grade... (really funny and you will probably yell at me )
My science teacher Mr. Dawson and I were good buddies. I would go to his room after school and start messing around with his chemistry stuff because he saw potential in me. One day, he decided it would be a good idea for me to go grab him some baking soda out of the chemistry room. He came with me, and we spent about 2 hours in the chemistry room.
First, I came across some HCL in a METAL ACID CABINET (stupid idea) with some paint chipped off. The lock was so damaged from the fumes, it fell off into peices, leaving me staring at 30% 12M HCL in the cabinet.
I grabbed it and poured about 250ml of it into a flask, while avoiding the fumes erupting from it. I then put the HCL on a bunsen burner to boil some water out of it, to make it more pure . After a while, 5 minutes or so, I then took it off and measured the acidity of it. It was pegging out at 1. I then took it back to his room to experiment.
WHile back in his room, I heated the solution up again and came up with a test: I would put 5 metal strips in 5 different test tubes and pour the HCL into each. There was Zinc, Aluminum, Steel, Brass, and Copper. I poured the solution into each and watched the Zinc and Aluminum start dissolving rather quick. The Copper was partially dissolving also. That was awesome. I then turned to put the cork back in the flask and my labcoat caught the edge of the flask, spilling it all over the chemical resistant desk. The only problem was, was that there was aluminum foil everywhere on the desk, not to mentition his papers he was grading
I ran out of the room, while you could hear everything dissolving. I could hear him say: "WHat did you do now?". Followed by "Holy **** What did you do!!!" I went back in and told him that I spilled the HCL. He then put water on it, which was bad by his part, causing a exothermic reaction. I told him we had to get baking soda or a base chemical, so he poured baking soda all over it. It was now a gooey mushy mess, that was very yellowish green in color. We then had to pour it into a LDPE container and put some chemical stickers all over it. It is still sitting in his closet.
EDIT: Spelling errors
