Hello guys, I'm new to this forum. ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm trying to figure out if an HDMI socket is worn out.
So what I did was to connect a HDMI cable cut in half with it's wires exposed and check continuity on the pins at the pcb, but there's this wire, a white one, that seem to be connect to a lot of pins, also a blue wire that is connect to 2 pins.
The blue wire resistance on the pins is 2k ohm, also the white wire resistance is 2k on most pins it's connect except one.
Is everything OK?
Thanks in advance!!
Is everything OK?
Thanks in advance!!
